Annotation family Instance Parameter cannot edited by clicking
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
protikkayal
2571 Aufrufe, 12 Antworten
I have a detail item line based family. As inside the detail item family template "Label" Label.jpg is not available, I used a "Generic Annotation" family nested inside it. 'Generic Annotation' family contains a 'Label' shared parameter.
When I load the family to project then I had to change the parameter value from the 'Properties bar', I can't edit it by clicking on it, Please see the attachment for better understand.
Is it possible to change the parameter value by slow double click on it as a annotation label?
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: protikkayal
Did you associate the nested family label's parameter to a parameter in the host?
...maybe I misunderstood you. Do you have the Family's Label parameter available to you in the Project and is it editable?
Nachricht 3 von 13
protikkayal
als Antwort auf: barthbradley
Yes I did that, but it not gonna work.  Better I am attaching the family for your review.
Thanks.
Nachricht 4 von 13
protikkayal
 I can not attaching the .rfa file here now, how can i suppose to do it?
Nachricht 5 von 13
Do this.
Tags (1)
Nachricht 6 von 13
protikkayal
als Antwort auf: ToanDN
Yes I did that, but not happening, please help how can I share the family file here. Attachments are not posting, don't know why, any other option to share the file here?
Nachricht 7 von 13
zip it then attach.
Nachricht 8 von 13
protikkayal
Family file is attached here
Nachricht 9 von 13
Works here.
Nachricht 10 von 13
protikkayal
My concern is that, the value is not changing by slow double click, i have to change it from properties bar, is it possible to do such any way then i can edit the text by slow double click on it(For example we change the dimension value by clicking on it and then type the value) inside the project?
I think now i am clear to you.
Nachricht 11 von 13
Because the label is in a nested family. The ability to edit it directly on screen is only made available when the label is created directly in the family, in other word, only for annotation families and tags.
Nachricht 12 von 13
protikkayal
That's the thing i actually wanted to know, thanks for your help.
Nachricht 13 von 13
shujath36
This feature is a must. I raised an idea for the products team.
Double Click to edit label for nested family - Autodesk Community
