Announcements
Annotate tab missing in Adaptive Revit Families
Hi there!
I used the Metric Generic Adaptive Model template to create quite a complicated shape (Family). I need to get rid of some lines in the plan view in the project, but I want to control it from the family. Annotate tab is not there in the adaptive template and loading annotation families doesn't work! Even when loaded, I cannot use them as apparently they are not treated as components!
Tried with Visibility Settings, but then if I set a line to disappear in all views, the whole important frame work disappears too! And there is no symbolic lines to recreate in this view nor option to loaded? At least not that I know of.
Please, help!!
Thanks in advance!
dzanta
can you post the revit family so i can look at it?
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Sahay_R
Please share the family.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Annotation, Profiles, and Detail components are not available in Adaptive family environment.
Viveka_CD
Autodesk Support
Autodesk Support
Hi @Anonymous
Adaptive components do not have 2D features such as annotation nor symbols or detail items and filled regions and they are used in conceptual massing based on their definition of adaptive points.
Coming back to your original post, you've mentioned creating a complicated shape (Family) and not able to delete these lines. Maybe you can control the adaptive points? Can you post the family?
Looking forward to your reply update.
