Angular dimensions more than 180°
2 ANTWORTEN 2
Nachricht 1 von 3
aali8N6WQ
311 Aufrufe, 2 Antworten
Hi All,
For angular dimensions, I cant seem to understand why Revit will not let the user choose different angles required to be annotated. For some reason, angular dimensions work differently between detail lines and filled regions. See below screenshot for reference.
Originally wanted to create an angular dimension in drafting view showing the outside angle. Had to workaround and use a filled region to achieve this. Is the angular dimension calculation different based on object? Am i missing something?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: aali8N6WQ
Nachricht 3 von 3
aali8N6WQ
als Antwort auf: barthbradley
Seems like a counter active process to dimension and adjust to suit prior to drafting the actual lines
