Angular dimension(angle 0/90) - constraints are not satisfied
1 ANTWORT 1
Nachricht 1 von 2
1080667GMU9L
164 Aufrufe, 1 Antwort
Hello guys
I am modeling the steel beam profile in the generic template. What I am struggling with is setting up a parameter to 0 and subsequently back to 15 (as an example)An issue is that once I adjusted the parameter to 0, an error telling me constraints are not satisfied pops up.
I have tried to adjust the new parameters but however,  I tried it always ended up saying that constraints are not satisfied. Moreover, I found out that I am using reference lines instead of reference planes, is that an issue?
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: 1080667GMU9L
Not sure what you are trying to do here.
This?
(Extrusion omitted for clarity)
