Any suggesions on creating a view showing elevation as in the image? (Supposing the whole facade is a slope and I need a view showing the perpendicular surface)
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Hallo,
first you have to draw the facade. Then fetch the tool: view.
If you go nearby the facade, the view will change the direktion.It will be rectangular to your surface.
Regards from germany,
Stefanie
You can create a section at any angle in another section or elevation view.
Hallo,
than you can work with the section. You draw the facade, then you draw the section . You take the tool "aligne" and choose the facade. Than you move the section on the position you want.
Best regards.
