Angled dimensions and annotations
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
2253 Aufrufe, 11 Antworten
first I'd like to say I am new to the forum so i hope i placed this topic the right way.
Now to my problem. I posted a pictures of my dimensions and annotation in an angled part of the building and I want it to display the opposite way. Like the text which is nearby.
I couldn't find any solution for this and I hope it is possible somehow. I am using Revit 2019 if that makes any diffence.
I will appreciate any tips for this. Thanks
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: Anonymous
I am posting a Picture as a pdf somehow didn't appear properly.
Nachricht 3 von 12
So I managed to set dimensions the way I wanted ...Annotate - dimension types - Set Read Convention to Up, then Left (left then up don't have the same effect).
Now I tried almost everything in door tags but couldn't find anything at all. I simply can't understand why would they make text be able to set like not readable and thus rotate it the way I want, but not labels (not readable doesn't work at all)....
HELP !
Nachricht 4 von 12
Vertical/Horizontal not working for you? (using Options Bar or Spacebar)
Nachricht 5 von 12
als Antwort auf: barthbradley
Thank you for reply, but unfortunately no. I need the tag to rotate with element. I edited family to not rotate with doors and set it to vertical - text is faced the way I want but it looks strange angled to a door axis. (see the Picture i uploaded).
I think there should be a text orientation setting to labels like it is to text and dimensions? Because the only other option I see here is tu manually aplly text to every door which is the exact reason I stopped working with AutoCAD.
Nachricht 6 von 12
It's been a Wish List item forever.  Autodesk has done nothing about.  Someday maybe.
Nachricht 7 von 12
Corsten.Au
Hi
in the tags try to find
” rotate with components “
that should help you.
cheers
Corsten
Building Designer
Nachricht 8 von 12
als Antwort auf: Corsten.Au
I uploaded an image above - rotated with compoment, but I want to change text orientation...If it is how " barthbradley" said I have no comments. It is such a basic thing, but so necessary for a sheet to look properly.
Nachricht 9 von 12
Revit was originally created based on the US graphic standards so upside down annotation is considered non-compliant.  They may have fixed the text to give flexibility but not labels.
Nachricht 10 von 12
Corsten.Au
Hi
Check this screencast
https://autode.sk/2S9a7kY
secondly if you rotate the label in the tag by 90 degrees. you will get second type of tag which is perpendicular
to the element ( door in this case )
does this solves your issue??
1. Rotate with Element 2. Rotate the Label in the Tags1. Rotate with Element 2. Rotate the Label in the Tags
Corsten
Building Designer
Nachricht 11 von 12
All of them are still right side up. Look at his screenshot again.
Nachricht 12 von 12
Just to be clear what I meant...I have tags set to rotate with component. My tags are faced at 95 degrees angle and I want it to display the same way as it is at <90 degrees. (doors are walls are rotated 185 degrees - see my second picture I uploaded).
I am afraid I will have to put actual text instead of tags there and close this topic, but I hope someone can still solve this so I will let this open for few more days.
Thanks.
