angled curtain wall grid lines distort when wall is sloped
4 ANTWORTEN 4
Nachricht 1 von 5
obeck002
324 Aufrufe, 4 Antworten
I'm having an issue where I am trying to create grid lines that follow the angle of a sloped wall I am designing. I was able to achieve this but I also want the wall to be slanted. However, when I do this in Revit, the angled grid that I created becomes distorted. I've attached pictures showing what happens. If anyone has any suggestions of how else I can achieve this or how to fix this I would greatlyyyy appreciate it. :leicht_lächelndes_Gesicht:
4 ANTWORTEN 4
Nachricht 2 von 5
SteveKStafford
als Antwort auf: obeck002
 It's been awhile since you posted...if you're still wrestling with this...can you share a stripped down file that contains the curtain wall that is doing this?
Steve Stafford
Nachricht 3 von 5
obeck002
als Antwort auf: SteveKStafford
Thank you for the response! I have attached the walls that have the issue.
Nachricht 4 von 5
SteveKStafford
You've swapped out the system panels for a Basic Wall type which is possible but not when you tilt the X or Y axis of the curtain wall grid. Only the system panels can tolerate the trapezoidal shapes that result.
You can:
  • restore the system panel type (create a new version for the material choices you want)
  • consider using to the Conceptual Massing Environment (CME) using massing and divided surfaces combined with custom adaptive point (4 point) families that can follow the non-rectilinear shape for the panels defined by your layout. You'll also need custom adaptive point (3 point) panel families for the triangular panels that will result.
Steve Stafford
Nachricht 5 von 5
Why don't you use Roof > Sloped Glazing?
