I try to keep the notch at center and stretch from both side. I am not sure what I did wrong. The family only allow me to stretch from the right side. When I move the left side, the notch doesn’t stay and move with it. Can you help me look at my file and let me know what’s wrong?
Gelöst! Gehe zur Lösung
Gelöst von nozci. Gehe zur Lösung
Just add another Equal dimension. When you stretch the notch stays at the middle of the line.
I want the notch not to move when I stretch both side. I don’t want both side to be the same length when I stretch.
If you assign a parameter to a dimension,
it gives you an arrow to slide <> Like this:
If you slide it only the line is sliding, and the notch is staying in the same position.
