I would like to know if I could assign an anfitrion to an imported object from AutoCad in Revit.
When I am going to place in a wall, it cannot adapt its position to it. Thank you.
No, but you can move and rotate it about in Revit.
Why not insert it into a hosted family and use that in the Project instead?
Insert into Revit Family. Check Work Plane Based and Unchecked Always Vertical. Load Family into Project and place on Face/Work Plane
You are misunderstanding. Insert the CAD into a Revit Family Template (RFA). Check the box next to Work Plane-Based, and uncheck the box next to Always Vertical . Both check boxes are in the Properties Panel of the Family. Now, load that Family in your Project (RVT) and place on Host. The host can be a Named Work Plane or a Face. Look on the Contextual Tab when you place an Instance of the Family in the Project. You will see both Host options. Pick one.
Properties in Family:
Contextual Tab in Project:
