An unrecoverable error has occurred
4 ANTWORTEN 4
Nachricht 1 von 5
b.vrenken
314 Aufrufe, 4 Antworten
When I want to open a Revit file in Revit 2022, I get the message that an unrecoverable error has occurred. This is a central model.
The strange thing is that my colleagues can open and edit this model without any problem. In doing so, I can open other models of the project in question in Revit 2022.
How can I open and edit this model again?
Thanks in advance!
4 ANTWORTEN 4
Nachricht 2 von 5
Tom_Kunsman
als Antwort auf: b.vrenken
I would delete all Windows Temporary files first. In File Explorer type "%Temp%" (without quotes). Select all files and folders and delete. There will be some files that Windows is still using, so just skip those. You will get a warning on those files.
I would then delete any local files that you have on this model. Try opening the central file with Audit option.
Hope this helps
Nachricht 3 von 5
Simon_Weel
And make sure you're all on the same Revit version. Revit sometimes doesn't play nice if there are different program versions in play.
Nachricht 4 von 5
b.vrenken
@Tom_Kunsman  @Simon_Weel
Unfortunately the solution does not provide any results. The same problem persists...
Nachricht 5 von 5
Tom_Kunsman
I think submitting a Support Case with AUtodesk might be something to consider next.
