Hi this has been happening quite a few times. Ive synced the same file earlier in the day and it worked i just tried to sync and it fails at reloading the latest and then i get this error:
Luckily it saved my local but when i opened my local and try to sync it I keep on getting this error. HELP!!
You want to check how many errors you have in the model. Sometimes you may have a corrupt object that lead you to this errors. So always clean your model on regular basis.
I would immediately locate and inspect your latest backup file. You may be needing it.
