Amending array in detail
1 ANTWORT 1
Nachricht 1 von 2
263 Aufrufe, 1 Antwort
In the detail view - I was trying to change the instances count or change the distance between items, but it did not work as I hoped.
I can change the distance only by moving one of the items, but I cannot move any by changing the number on the dimension line between instances. Is there any other way then just moving items by select and drag?
How can I add or remove number of instances in the array? The array line with number of instances does not appear in the detail view.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
you are going to need to post your family for us to examine.  Your description of the problem is compelling, but leaves much to the imagination.   But, if I had to  take a guess,  I would say it was the butler with the candlestick.  I could be wrong.
