do somebody knows if it will be possible to work in Revit/AutoCAD (simple models) on a laptop with integrated graphics card AMD Radeon™ Vega 7?
Yes you can work but with certain limitations (initially it will not be noticed), can work with a minimum 2GB card.
But if you want to work with renders it will not reach you.
Jamhmer Oc
if you can practice well in 2D plan there will no any problem but if you working a lot with 3D view you will face some problems because 3D navigation also consume GPU
You will experience some lag in your program if you don't meet the requirements to run the product. there are certain requirements to run latest version of REVIT you can refer to this LINK. thanks
