Hello community,
This is my first post here so I hope I can get help from you guys.
Like the subject says, I have the ambient shadows on each level turned on, but some how its only being shown on the 2nd and 3rd level of my building.
The most important plan is the site plan in which the ambient shadows aren't being shown.
I have the Hardware acceleration in the grafic tab turned on.
Is anyone having or had this issue ? I tried searching the web but didn't find a thread similair.
Thank you in advance
Cheers
Gelöst! Gehe zur Lösung
Gelöst von Zsolt.Varga. Gehe zur Lösung
Rodrigo Bezerra
Thanks for the fast respond.
All the levels are placed on the same ground level, I tried to play around and change the sun path settings but nothing changes only the direction of the shadows.
I even tried to place level 1 and 2 on the same view template with the same settings but ambient shadows are still seen on level 2 but not on level 1.
I think it's just a small setting that turns the ambient shadows visibility off besides the one on the graphic display options but I can't figure it out.
I attached a screenshot... The language is German but I think it's understandable.
Thanks in advance
Greetings
Rodrigo Bezerra
LoooL, I highlighted the Ambient shadow option to make it understandable, that was the point ![]()
On the ground plans ambient shadows add more depth in the scene. I'll attach a screenshot of level 2 to show it.
I appreciate your help, thank you.
If I get a solution I'll let you know.
Greetings
Rodrigo Bezerra
Check the Lighting options (Beleuchtung) and see if both views have the same values for sunlight, ambient light, and shadows. Make sure all the Sun Settings are the same, such as the "Relative to View" setting and the "Ground Plane" setting.
Sorry for the late respond.
I tried to have the same settings for all levels, even putting them in the same view template didn't help me further. I gave up and finally disabled the ambient shadows.
Thank you guys for your help.
Regards
Please, note, that the inconsistent behavior of ambient shadows in Revit has been reported to Autodesk´s Product Design and Development Team.
This incident is currently being investigated for a possible cause and resolution.
The current findings of the investigation have been documented in the article published here:
http://knowledge.autodesk.com/article/Inconsistent-behavior-of-ambient-shadows-in-Revit
This article is going to be updated by the development team in order to inform users about the news related to this topic.
Best regards,
HOW DID YOU DO?, I HAVE THE SAME PROBLEM UNTIL TODAY IN 2019 REVIT VERSION, I HAVEN´T SOLVED, CAN YOU TELL ME HOW YOU DID?, PLEASE... LOOK AT MY 2 IMAGES, THE SAME MODEL TWO DIFFERENT LEVELS, ONE AMBIENT SHADOWS WORKING, AND THE OTHER NO ... -_- ... HELP ME PLASE...THANK YOU!
