Is there any way to do this in Revit? I've tried duplicating and using different baluster panel families but if I make any mistake the pattern doesn't draw at all so making adjustments is problematic. If I include a post as part of the baluster pattern, then it might only work for an even number of panels. Thanks.
Gelöst! Gehe zur Lösung
Gelöst von dbroad. Gehe zur Lösung
Sure that can be done with a well-planned baluster pattern of properly-sized panels. What's specifically "problematic" for you?
This help?
Thanks for the reference. I'd learned most of that. Got it working. Had to add a post and the reversed panel to the pattern.
