Alter existing window family to cut through a wall and a curtain wall
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
Rytechdesign
357 Aufrufe, 5 Antworten
I am new here, please forgive me if this has been asked before.
I have a curtain wall on the outside of a standard wall, this is to create a panelled effect. I am trying to find a way to get a window family to cut through both wall types. Thanks, Ryan
5 ANTWORTEN 5
Nachricht 2 von 6
syman2000
als Antwort auf: Rytechdesign
Switch the curtainwall panel with a wall
Then host the window with the wall embedded into the curtainwall
Nachricht 3 von 6
jay_colcombe
For normal side by side walls you would need to join geometry between the neighbouring walls to allow the opening to be automatically cut.
Hosted objects such as a window or door in one wall will cut openings in a second parallel wall when the Join Geometry tool is used between the two wall objects.
Otherwise you would need to manually add wall openings to cut the other 2 walls at the window opening.
Jay Colcombe
Autodesk Certified Instructor
Nachricht 4 von 6
Rytechdesign
Can a curtain wall be joined to a standards wall?
Nachricht 5 von 6
Yes. You can join a basic wall with a curtain panel (also a basic wall type), then place a door or window then it will cut through both.
Nachricht 6 von 6
jay_colcombe
Yes it can as nicely shown above.
(Apologies for the delay - bed time here)
Jay Colcombe
