Hello, everyone, in a Generic model family I have to pieces as you can see in the picture, each one with a few voids, but when I try to erase one piece with the voids by selecting them with the rectangle selection the voids of the other piece are also selected and erased, and they have nothing to do with each other, other than been in the same family.
I would like to know the logic behind this behavior, and if there is a way to change it or avoid it.
Thanks in advanced!!
I am assuming that the voids are modeled separately; that is, they are not both in the same sketch. Right?
If so, something similar has happened to me as well. Long and short: I discovered it had to do with copying the original void, instead of recreating it from scratch. Does this workflow sound familiar?
Hi, I already fix the family manually, erasing one by one, but Yes I can confirm the behavior of selecting the copies, I just made a new family with a few extrusions and test this behavior. When I select with the rectangle selection all copies of that original void are selected but not others void created from scratch. Also I notice that if I select copies of the original with rectangle and not the original this doesn't happen. So I guess this is a weird behavior we will need to have in mind.
Thanks!
