Hi Everyone,
I recently downloaded Revit 2019 and when I go onto materials, every single material has that yellow symbol next to it!
Can anyone help?
Many thanks,
Pippa
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
That menacing little mark denotes Legacy Materials. Nothing to be alarmed about.
Ah okay, so it doesn't mean that the material (texture) isn't there and that it will be seen when rendered etc?
The project file could be upgraded from a previous version of Revit. The newer versions of Revit contain new material assets, and the yellow triangle shows that a legacy (older version) asset is currently in use.
you can refer to this LINK and see if helps. thanks
