All duct fittings are faded out and I cannot access them.
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1310 Aufrufe, 3 Antworten
So I've been having this issue since I started this project. At first I ignored it while working around. All the fittings and air terminals that I have placed are faded out and I cannot press on them. Now when I want to copy this system to the other floors revit only copies the ventilation units ignoring all the other ducts and fittings. I've been trying to solve this by reading millions of threads and couldn't find anything. Maybe i'm overseeing something. I've checked and tried all the visibility settings and so on.
I'm also on a rush to finish and present this project as I am a student and this is my semester project. Please help.
Thanks in advance!
3 ANTWORTEN 3
Nachricht 2 von 4
Erense
als Antwort auf: Anonymous
As far as i know it has to do with the View discipline.
The Discpline in your view is Plumbing. In Coordination it should be fine.
When you check the 'connected level' of the duct, it will be the current level but the fittings are on the lower level with an offset. Is this true for your model?
Otherwise try to disable the ' underlay' function for this view.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
Nachricht 3 von 4
RobDraw
When you use tab select on the ducts, does it select the fittings?
Post a small portion of the model so someone can investigate.
Rob
Nachricht 4 von 4
als Antwort auf: Erense
Changing it to coordination did not help. But disabling the underlay helped! How did I not think of that before.
Many thanks!
