All Curtain Panels Delete when I move my curtain wall
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
ssw9UZNL
695 Aufrufe, 3 Antworten
I am having a very odd thing happen. When I try and move my curtain wall or change a grid, all the panels within it delete and turn to empty panels.
I have created another curtain wall in the project and this seems to all work ok- so its not a bug with the file.
One caveat as that I made these curtain walls using the API- but I have quit the file and reopened it, so it would not be the API trying to push changes (I wouldnt imagine so).
3 ANTWORTEN 3
Nachricht 2 von 4
ssw9UZNL
als Antwort auf: ssw9UZNL
Edit- When I simply highlight the curtain wall and move it, all of the panels delete.
If I highlight and curtain wall AND the panels, the curtain wall and panel both move.
However, if I make a new one from scratch I only need to highlight the curtain wall and the panels automatically move. I want to be able to move the curtain panels within the wall by only moving the wall.
Nachricht 3 von 4
JoshEKing
I use LT currently, so I don't use the API.  But it sounds like some sort of hosting or linking problem.  Do your API calls create the panels in space from calculated/specified dimensions or directly from the Curtain Wall grid?
Have you tried making the frame and panels into a group to make selecting them easier?
Nachricht 4 von 4
ssw9UZNL
als Antwort auf: JoshEKing
I just solved  my own issue, all the panels were pinned- rather than giving me an error they just deleted.
