Alignment Tool Bug or Something Else?
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
BigPicture045
671 Aufrufe, 7 Antworten
The past two project I have been working on I've been experiencing the same alignment bug. I'm calling it a bug, but wanted to check and see if anyone can spot anything I'm doing wrong. The only thing I can think that I have done differently in these two project is to use grid lines more so than I normally do.
As you can see from the video below, when I try to align certain elements, they behave in an odd manner. I had a terrible time with aligning fascia boards. Had to use different methods it was so bad.
https://autode.sk/3n0s3h8
7 ANTWORTEN 7
Nachricht 2 von 8
syman2000
als Antwort auf: BigPicture045
Can you upload the sample file and see if we are able to replicated the same issue?
Nachricht 3 von 8
alan_eu
Hi @BigPicture045
That´s not a bug, but a unjoin elements warning.
Your floor is joined with another one and you are trying to move, loses its join status, so the Revit warns you.
Unfortunately, we can´t turn off this kind of message, so we have to learn how to live with it :leicht_lächelndes_Gesicht:
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou :leicht_lächelndes_Gesicht:
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! :leicht_lächelndes_Gesicht:
Nachricht 4 von 8
BigPicture045
als Antwort auf: syman2000
By sample file are you talking about the project file? Or is the sample file something different that can be exported from the project file?
Nachricht 5 von 8
syman2000
project file. I want to check if I am having the same issue. Then Autodesk can confirm it is a bug and they will fix it quickly. If I am not having that issue, it could be something in the file that cause that issue.
Nachricht 6 von 8
BigPicture045
Please see the attached project file. I can confirm that I re-saved this project under another name, purged the file, and was able to replicate the first mentioned bug.
Let me know what you find.
Nachricht 7 von 8
syman2000
I look at the file and something is out of wack with the align tool. However if I cut and paste the floor slab at the same location, the floor slab works as intended when I align with the other floor slab. I've check and see if there is constraints and found none. It is bizarre behavior.
Nachricht 8 von 8
BigPicture045
Thanks for checking it out syman2000. If this continues to happen in other projects I will bring this up again. Lately, I have not had any issues with this bug.
