Alignment of Plans
7 ANTWORTEN 7
Nachricht 1 von 8
tstewart
324 Aufrufe, 7 Antworten
Alignment of Plans
Basement and Ground floor plans are not aligning (it appears that they are rotated). How to align levels/floor plans?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: tstewart
If they are modeled in Revit, do one of the following:
- Check Project North/True North of those plan views and make sure they are consistent
- Create a scope box and assign it to both floor plan views
If they are CAD, then there are other ways to fix.
Nachricht 3 von 8
tstewart
als Antwort auf: ToanDN
Both are modeled in Revit and orientation is Project North.
Nachricht 4 von 8
Were they ever aligned?
Nachricht 5 von 8
tstewart
als Antwort auf: barthbradley
Yes - the same issue that I thought was resolved over this past weekend has resurfaced. Plans are not aligning and look skewed.
Nachricht 6 von 8
So they aren't actually aligned at all.  Did you trace the floor plans from CAD files?  Did you even set up Grid lines?  To confirm, open a 3D view and see.
- Create grid lines in the correct floor plan
- Open one floor plan to be fixed, select everything, make a model group, rotate the group to align with the grid lines
Nachricht 7 von 8
Is this related to your PDF Site Plan thread?
Are you tracing a PDF copy?  Sounds like you did.   PDFs are View-Specific.
Nachricht 8 von 8
tstewart
Yes
