I used to align views on sheets by placing a reference line within a plan, elevation, or section, then using the "Move" tool to align them precisely with other sheets.
However, when I try doing this in Revit 2024, I now encounter the error message shown below.
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
Make sure Disjoin is not checked on the Options Bar when you use the move tool on views.
Steve Stafford
