I want to align the roof in the picture to the curtain wall, but align tool does not work. I define the slope, but it's hard to calculate exactly the right angle. Is there an easy way to stick the roof to the walls?
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
How did you create it here? Did you use alope arrow, defined roof slopes, offset from roof base, roof by extrusion?
The first three are all methods for roof by footprint, but I'm guessing you've used defined slopes. You could explore using slope arrows which you can then define by slope or height when selected: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN... And if you're having trouble figuring it out you could consider posting the file, easier to see what's what...
try this:
Go to a Elevation View, draw a Reference Plane aligned to underside of the sloped roof, and then select the Curtain Wall, press Attach Top/Base on the Contextual Tab and pick the Ref. Plane as the target.
try to edit your roof if you see a slope arrow just remove it and or share the file so we can check and see if helps. thanks
