Gelöst! Gehe zur Lösung
Gelöst von protikkayal. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
If the "Core" of your question is whether or not you can change a Curtain Wall's justification to something other than Centerline; then the answer is: you can't. You can offset panels and mullions, but that's not going to help you with aligning to Grids.
Simply select the storefront, one blue dot will appears in both ends of it.
Just right click on the blue dot, and select "Disallow Join"option from appeared menu.
Do it for both end of the storefront.
Now you can able to move the storefront to anywhere you want by selecting the storefront and just move.
Hope your problem will solved.
