Aligned Dimensions to Centerpoint of Cylindrical Lights
7 ANTWORTEN 7
Nachricht 1 von 8
pjasperR6YKL
419 Aufrufe, 7 Antworten
The project I'm working on is not rectilinear and includes lights that are arrayed along a curve. I'm trying to have an aligned dimension string notating the center points of can lights but cannot seem to figure it out.
Drawing a detail line circle on top of the fixtures is one workaround, but doesn't seem efficient. I tried drawing a model line circle within the lighting family and turned on Center Mark Visible, but this doesn't seem to solve it.
@ToanDN @barthbradley any ideas?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: pjasperR6YKL
I'm not clear what you are trying to do. Do you have a screenshot or something to illustrate what you are describing?
Nachricht 3 von 8
pjasperR6YKL
als Antwort auf: barthbradley
I would like to have a dimension string from the angled wall on the left. The green lines approximate the reference planes of the can light fixture.
Nachricht 4 von 8
Draw a reference line from the center of the line.  In project, place dim from a grid line first and TAB to pick the end of the ref line in the family for the second witness.
The OOTB fixture works right OTB without doing anything.
Nachricht 5 von 8
Why don't you use a Scope Box to rotate the View to make the angled wall perpendicular in the View, and then pull your dimension string?
Nachricht 6 von 8
Or do a a rotated Call-out and pull your string in that View.
Nachricht 7 von 8
pjasperR6YKL
Thanks for the replies @barthbradley and @ToanDN. The project is set up on a radial grid which makes things a bit more complicated. The snip I posted is a call out plan view that is puts the centerline of the overall space page north, the resulting perimeter walls are still angled / curved.
After some testing, I'm going to use a symbolic line in the lighting family and snap to the end that starts in the center.
Nachricht 8 von 8
Honestly, if placement location is critical, I would try to locate them from some perpendicular reference point that can be found in the field.   Sounds like the envelop in curved, so what about an interior partition?
