Aligned dimension is not working
3 ANTWORTEN 3
Nachricht 1 von 4
mansouriash
3214 Aufrufe, 3 Antworten
Hi everyone. Aligned Dim isn't working for exterior walls. when I click on the wall nothing happens!
can anyone help me plz?
Beschriftungen (1)
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: mansouriash
May this help. Thankd
220eaef2-b2ca-4918-9c26-3ab86f148fe5,
Nachricht 3 von 4
constantin.stroescu
  • If you use Aligned with Entire Walls options - this will work only for Right angled walls (1)
  • otherwise , you have to use Individual References :
    • hover over the intersection point till a blue point appears then click
    • repeat the process for the second point
Constantin Stroescu
Nachricht 4 von 4
constantin.stroescu
1- Pick Entire Walls
2-Pick Individual References
Constantin Stroescu
