aligned dimension for vertical line in 3d
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
763 Aufrufe, 2 Antworten
hi there
am trying to to dimension a vertical line in isometric view but the dimension go exactly from the points i choose to the text
how can i make a perpendicular line to the vertical line then put the dimension on it
I attached an image for you to get the point
the problem at picture (1) and the thing I want is at picture (2)Untitled.png
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Not  sure I understand, but if you're having trouble pulling a dimension off the geometry the way you want, then lay down some Ref. Planes and dimension between them instead.
Nachricht 3 von 3
Set the workplane where you want the dimensions to lay on before placing them.  See screencast.
