I'm very new to revit and following the No Experience Required book step by step. So far so good but I'm now not able to create a dimension of an angled wall. When I click the tab button several times to get the little square grip as the book says, it cycles through many options except that square grip, which I need. I have the following selected:
Annotate Tab
Aligned
Wall Faces
Individual References
I don't know what I'm doing wrong! Please help.
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Anonymous
I see that you are a new visitor. Welcome to the Autodesk community!![]()
Please see article on Aligning dimensions on angled walls and let me know if this helps.
See simple screencast below:
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi Viveka, thank you so much for the screencast, I had the same issue and managed to place the dimension thanks to your instructions. My question is, in what situations would we find the option to pick "entire walls" useful? Are you able to post a screencast showing it in action? I have drawn lots of walls, straight and angled, and tried to use that option but it never seems to work. (I'm using Revit 2019)
