Align Views between Sheets
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
ndawsonmccann
2519 Aufrufe, 4 Antworten
I have not seen a clear answer on how to align views across sheets so that when you flip through your PDF, the views are always in the same location. I have to resort to drawing a line to align to and copy that line across pages and align the views and then delete the line. There has to be a better way?
Tags (1)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: ndawsonmccann
- You can align reference planes or grid lines/levels placed in views to sheet's guide grid or titleblock border.
- For legend views, you can copy paste aligned from one sheet to others.
- Beside those, i am sure there are add-ins to assist this task.
Nachricht 3 von 5
RDAOU
@ndawsonmccann
Check dynamobim.org there are several discussions on how to align views across sheets using dynamo
Nachricht 4 von 5
Nachricht 5 von 5
RSomppi
I've used to grid guide for this. While not precisely accurate, it good enough for page flipping.
