Align elevation tag with grid line
2 ANTWORTEN 2
Nachricht 1 von 3
teohjingrou
752 Aufrufe, 2 Antworten
I have rotate my elevation tag to the nearest angle to be align with grid line as I can. However, it still cannot reach the perfect angle to parallel with grid line as the rotate tool can't adjust the very small angle. Is there any solution? I hv attached a video showing my problem and my revit file.
2 ANTWORTEN 2
Nachricht 2 von 3
RPTHOMAS108
als Antwort auf: teohjingrou
One way I know of:
Draw refplane from origin of elevation tag perpendicular to grid.
Select rotate command
Drag centre of rotation (blue dot) to end of refplane and release
Pick current quadrant of elevation nearest to grid
Pick point on refplane
Here is a link to a screen cast which may or may not work now and probably won't in the distant future:
https://autode.sk/3bltUtw
Nachricht 3 von 3
RDAOU
@teohjingrou
Use a framing Elevation
