Align Dimension to tilted line
santrod0204
Message 1 of 23
santrod0204
Hi everyone,
I was asked to align the dimensions marked in the image underneath with red with the wall that's on its left (The one that follows the slope on the dark blue line) while showing the same dimensions that are currently shown.
I have never done that, neither have I found an option around (not at least as obvious as I need) to do that with a couple of clicks. So my question is... Is that even possible in Revit? And, if so, how can I get there?
Replies (22)
Message 21 of 23
@jay_colc wrote:
They were by mistake I will make sure in the future I ensure that it will not happen again as I don’t won’t to do this AGAIN!!
All good.  Thanks for the clarification!
Message 22 of 23
anze.kumar
I understood your answer was specific to dimension with points.. I was trying to add Detail Lines into solution.
However the solution of my answer is somewhat the same as yours. I apologize, noted for the future, will not do same thing again. I would like to add to Revit community rather than make it more "competitive" and not transparent.
Good day.
Message 23 of 23
jay_colc
It is absolutely fine, as you state you were expanding on the original solution and offering another method of application.  We are all here to help.
Jay Colcombe
Autodesk Certified Instructor
