Algorithm for constructing an ellipse embedded in a rectangle Revit Archi 2019
8 ANTWORTEN 8
Nachricht 1 von 9
dedperded2025
648 Aufrufe, 8 Antworten
Подскажите пошаговый алгоритм построения эллипса встроенного в прямоугольник размером 105,6см х 39,6см в Ревит с помощью стандартных линий и окружностей.
Tell me please a step-by-step algorithm for constructing an ellipse embedded in a rectangle of 105.6 cm x 39.6 cm in Revit using standard lines and circles.
8 ANTWORTEN 8
Nachricht 2 von 9
bill_gilliss
als Antwort auf: dedperded2025
This method will approximate an ellipse with arc segments, using a true arc as a guide, and is much faster than any method that requires geometric construction. The first arc segment is created using the Start-End-Radius Arc tool, and all the rest are with the Tangent End Arc tool. Easy.
64d86b08-45c9-4cbe-8eb8-18ced25d7d81,640,620
Nachricht 3 von 9
Alfredo_Medina
Just curious, why you don't want to use the Ellipse tool to draw an ellipse?
Nachricht 4 von 9
bill_gilliss
See if I can get the screencast to work this time:
Nachricht 5 von 9
bill_gilliss
One more time. (It took a while for the Autodesk servers to get this ready.)
Tags (3)
Nachricht 6 von 9
dedperded2025
als Antwort auf: Alfredo_Medina
In particular, I am building an architectural wall based on an ellipse. But the drawing tools on the walls don't have it.
Nachricht 7 von 9
Create an elliptical  mass form and generate the wall by face.
Nachricht 8 von 9
constantin.stroescu
als Antwort auf: ToanDN
I'll complete that because the dimensions of the ellipse are so small you have to place Wall by Face > Finish Face Interior...
Constantin Stroescu
Nachricht 9 von 9
bill_gilliss
I'm TRYING to get screencasts to work. Here it is as an Mp4.
