I am trying to a gable roof that is at and angle, but the slope goes up as the angle gets longer, see pictures.
Gelöst! Gehe zur Lösung
Gelöst von GustavoUbriaco. Gehe zur Lösung
Hi! this corner causes the conflict try to make one single line or if it's necessary to have both maybe the solution is put a slope arrow or split segment.
Gustavo Ubriaco Contreras
how about uncheck defines slope and use this?
Also you can rise another corners if you want some like this
Here is a better view
that is a great problem
If you want I have revit 2019 and 2021 I can help you to do that easy job
in 5 minutes
That would be amazing. this is what I am trying to do.
Cool could you draw how is the roof here please? and the red ones are like I draw?
I tried to send you a message but I can't if you like let me know if I'm ok or wrong
do you want this corners at some elevation?
If you like check in the file and let me know the changes to improve this roof, feel free to let me know please
Your welcome I'm glad to help you all you need let me know!
Any have company recommendations for re-building roof? I know how to important keep apartment to save, I would like to rent couple small apartment to guest in North Ireland. I found some company who can do that https://litcore.ie/ someone worked with them?
