After reinstallation Revit Crashes When Sync to BIM 360
studio
studio
I had to reinstall Revit in 3 PC in my studio, due to a change of licences.
In 2 of them, when i try to sync a model to BIM 360, Revit suddenly crashes.
I 1 of them everything work whell.
Also, if if try to start a collaboration in a new model, the message appears.
ennujozlagam
hello, try to install latest updates from autodesk and check all user's involve in the project must be in the same build and see if helps. thanks
studio
Uninstall everything, then reinstall!
And so all works fine!
studio
Problem not solved! it worked for a day, and then crash again!FILE JOURNAL
