my issue is, that after opening revit (in admin mode, with exception on windows defender windows 10, also my laptop I use to work with CAD software like AutoCAD and also revit) and startin my project I used to work on or any sample project, I only have a white screen. All functions are active and all Tools can be used, but if I draw a construction line, it does not appear. in any view or 3D view or front or side views, or floor levels.
Is there anything I may have not seen so far, or any change I need to thinka bout?
Thank You in advance
kind regards
Alchast
Do you have an older version of the program that will open and old project properly? My first thoughts regarding laptops would be graphics and memory. What OS are you running?
What are your computer specs? Just because it works for Autocad does not mean it will work for Revit too.
hello, try to untick your use hardware acceleration from options and see if helps. thanks
