Revit Upgraded the model from 2018 to 2022 and some of the eorrors i have found as given below .I want to understand they are any critical model errors are ignoreable.
Error Number 01.Can't move element.
02.Equality constraints are not satisfied. The action either violates a locked constraint or tries to modify a sketch based object outside of the sketch mode.
I have element IDs but I nee your suggestions and advises on this to make my model error free to be upgraded to 2022 without anything missing from 2018.
I am checked with element ID for the first error I am found there is no change and nothing has been deleted what canused this error.
Based on the errors you've pointed out, it seems that there are two issues at play. Your elements are fixed, which is preventing you from moving them. Try the following:
Error 01: Can't move the element.
Error 02: Equality constraints not satisfied.
