Aframe DOOR
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
cadwork12
252 Aufrufe, 2 Antworten
Aframe DOOR
I constructed a simple a frame, I used a curtain grid for the front wall.  I need to create a glass door for the entrance.
In a tutorial it said to select the area of the door and it a drop down there should be option to create a door.  However
I'm not finding the door option.  Any ideas?
2 ANTWORTEN 2
Nachricht 2 von 3
eizinmyat
als Antwort auf: cadwork12
As far as I know, the types of the doors that we can choose is also depending on the templates that we choose. Like you mentioned, if you want the glass door, click the frame and choose the door type from the drop-down list in the Properties. I hope it can help you. Thank you.
Ei Zin Myat
Technical Sales Unit Engineer
ONESTRUCTION Co., Ltd.
eizinmyat@onestruction.com
Nachricht 3 von 3
Load a curtain wall door family, then you can select a panel and change it to a door type of that family.
