When I try to edit a material and load a new one in from the library, after opening the Material Browser there is no window showing the Autodesk Material library and no option to turn in it. Anybody know how to turn this feature back on.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
First of all, do you have the AECMaterials.fbm folder? Go to C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\20xx and see if you do.
It does not appear that I do, not sure how that would happen as i used it last week for a different project.
