Gelöst von RDAOU. Gehe zur Lösung
Gelöst von XXalessio.amodioXX. Gehe zur Lösung
@Anonymous
You can easily model it as a Railing Baluster or a railing panel
You should be able to do that with one baluster in the middle and then use a panel in between. Can have a better look at it later.
How can I rotate the panel?
If change in type properties the lenght with the depth doesn't change.
To put the shape inside the panel have to use a new family type'
Thank's
Edit the existing square baluster and you get something similar to your photo
