Advanced Sample Architecture Files 2018-2023
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
egillenVXTDW
7868 Aufrufe, 7 Antworten
Hi, I am trying to download the Advanced Architecture Sample Projects on Revit from 2018-2023 however, the only versions I can actually download for are 2020, 2022 and 2023.
https://knowledge.autodesk.com/support/revit/getting-started/caas/CloudHelp/cloudhelp/2018/ENU/Revit... 2018 link is unable to be downloaded
https://knowledge.autodesk.com/support/revit/getting-started/caas/CloudHelp/cloudhelp/2019/ENU/Revit... 2019 link is unable to be downloaded
https://knowledge.autodesk.com/support/revit/getting-started/caas/CloudHelp/cloudhelp/2021/ENU/Revit... 2021 link is unable to be downloaded
Can someone point me in the right direction to get the Sample Projects for 2018, 2019, and 2021? Live Agents have also been unable to download these files so if the Webpage and links could be assessed that would be great.
Eunan
Beschriftungen (3)
7 ANTWORTEN 7
Nachricht 2 von 8
I am afraid I can't help, but could you let me know where you were able to download the 2020 sample files? The oldest I can find available is 2022.
Nachricht 3 von 8
egillenVXTDW
als Antwort auf: egillenVXTDW
Nachricht 4 von 8
Thanks, much appreciated!
Nachricht 5 von 8
esk0r
There is some sort of problem with downloading older versions of the sample files but if you use Edge browser, at least for me I get some sort of download and then if you change the extension of the .crdownload files to .rvt, you will be able to open in Revit as normal.
Also adding some of the samples in case you can't even get the .crdownload files.
Rene Pellicer Garcia
Nachricht 6 von 8
esk0r
als Antwort auf: esk0r
These are the 2021 advanced sample project files.
Nachricht 7 von 8
esk0r
...and these are the 2019 advanced project sample files.
I have all sample files from 2016 to 2023, so just let me know if you need anything else.
Nachricht 8 von 8
egillenVXTDW
Thanks very much @esk0r this is exactly what I need.
