Adustable text box in a tag
aidan_hawkinsRJNAQ
Message 1 of 8
aidan_hawkinsRJNAQ
Hello
I have created a tag with has a label for description for walls.
When I place the tag in my plan views, I do not have the ability to adjust the text box so I can condense the text appropriately.
How can I add this adjustability?
This is my situation at the moment, I can not adjust this text:
And this is what I would like to be able to do, adjust it appropriately:
Thank you very much
Replies (7)
Message 2 of 8
vitorbortoncello
Autodesk Revit does not allow adjustments or the use of reference planes to control the box.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-change-the-...
Did you like this post? Don't forget to like and accept it as a solution!
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 3 of 8
aidan_hawkinsRJNAQ
Okay so there is no way to adjust the text box in a tag?
For example, I do not have the two nodes at the end of the text boxes to adjust them.. I would really like to have them
like this. but in project space I dont have it
Message 4 of 8
David_W_Koch
Revit will not allow that in a tag.  The closest you can come to that would be to set up multiple labels in your tag, with a range of widths, each tied to a Yes/No parameter for visibility.  Then create a Type for each label, and only turn on the visibility of a label in its type.
In the project, you can select the type with the width closest to what you want.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 5 of 8
Tom_Kunsman
I don't think there is a way, but can you post the family?
Message 6 of 8
azad.Nanva
@aidan_hawkinsRJNAQ :
this is only a discription for the wall so ,yes there is,you can use the multiline text as a parameter and use a variable like mine:
(view in My Videos)
Message 7 of 8
aidan_hawkinsRJNAQ
This seeems like the solution! But you have lost me at the part where you have the option to select multi line text.. in my revit 2023 it doesnt show.
Message 8 of 8
azad.Nanva
you should make a new shared parameter in the first  , this is make the shared parameter and use it in tag and project:
(view in My Videos)
