Hello I am practicing on Revit family and I was modelling parametric shelf with brackets. I am trying to do everthing in parametric but when I combine shelf and bracket families I can't change bracket's measurements due to it's change direction. As you can see from the image 1 when "h" value changes It tries to push the top where different Revit family is and it causes an error. Thats why I want to alter "change direction" and tried to pin one reference plane and leave the other. But then it still causes an error as you can see from the image 2. I also uploaded my Revit file, so I would appreciate it If you can help me.
Just do it in the Project. Either via "Elevation From Level" or "Offset From Host" Instance Parameter
Hello thank you for your reply but as I will be moving on complicated projects I would like to prevent doing manually. So If there is a more proffesional way to handle that It would be more appropriate for me and others as well.
Hi @mehmet_emin_anarBH6RC
Thanks a lot for posting your question to the forums! Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
with additional explanation and fix the problem:
Thanks a lot for posting your question to the forums! Has the solution suggested by @azad.Nanva helped with your issue?
Jonathan Hand
