Adjusting chimney height
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
zeromski
223 Aufrufe, 4 Antworten
Hi
I have a problem adjusting the height of the Generic_Models_Masonry_Chimney_Wall component in my Revit model.
I load the family and insert it then I edit the heigh using the Edit Type-Duplicate, however the chimney crown stays at the same height and just becomes thicker, see pictures below (I hope they appear in the message).
EDIT: I am working on Revit 2025
Before - Automatic height of 7300
After - Height adjusted to 5000
Has anyone experienced the same problem or knows of a solution I can try? I'm new to Revit so I don't know much about editing families.
4 ANTWORTEN 4
Nachricht 2 von 5
Tom_Kunsman
als Antwort auf: zeromski
can you post the family?
Nachricht 3 von 5
zeromski
als Antwort auf: Tom_Kunsman
I've attached the .rfa file.
It's from the UK Families pack in the Generic Models folder.
Nachricht 4 von 5
alan.johnson7YLND
Its just the top part of the chimney that isn't locked to anything, so when you changed the 'Top of Masonry Height'
it appears as a bigger extrusion. As per your second image.
If you can edit the family and lock this to the Ref planes already there that will fix it. See image below
Nachricht 5 von 5
zeromski
als Antwort auf: alan.johnson7YLND
Thanks, that makes sense.
I'll look into how to edit the family object and report back if the solution doesn't work, but I suspect it will.
