The quickest and probably easiest thing would be to slightly change the size of your body text. It is in the Appearance tab of you schedule properties. Only concern is the yellow column, not sure what that is reporting but it seems to be causing the large row heights.
Try adjusting the body text height, if that doesn't work i will need some more info on that yellow column.
Thanks!
Nicholas Seibert
Principal Revit QA
