Adjust material on a single face
2 ANTWORTEN 2
Nachricht 1 von 3
mbartolucci
692 Aufrufe, 2 Antworten
So I have a wood column. On three of the sides of the column, the grain is going in the correct direction, but on the other face, its perpendicular for some reason. Is there a way to adjust the material on this face only?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: mbartolucci
Yes; but there are several different approaches to do this depending on the scenario.  Post the file.
Nachricht 3 von 3
The face maybe got painted. Remove the paint see if it corrects the material orientation.
If not:
- temporary add a model pattern as the surface pattern for the wood material
- paint that face with the same material
- tab select a line of the pattern on that face and rotate 90 degree
