Ayee,
Ground is not even, and house like a lot stairs, how can I display on "Underground" level floor all stairs which are on different elevations? Without overlaying other floors on "Underground" level.
Solved by RDAOU. Go to Solution.
Solved by ToanDN. Go to Solution.
FOr plan regions to work... The stair need to be entirely within the boundaries of the plan region...ie: you need to align them to the External finish face of the Façade wall
Otherwise, you can overlay views on the sheet
