Addins tab disappeared
4 ANTWORTEN 4
Nachricht 1 von 5
fpensa
777 Aufrufe, 4 Antworten
Hi everybody,
Pretty much what it says in the title, the addins tab disappeared god knows why. Same in all the Revit I have installed (2018@2021).
I needed the NWC exporter, so I re-installed it and the addins tab got back but with this utility only... no trace of eTransmit, ModelReview, Worksharing Monitor or BatchPrint. Since these are all embedded features which you cannot download separately, I uninstalled Revit et reinstalled (I've tried to repair before with no luck), but the Addins tab is still mostly empty..
No idea where to look now... anybody got an idea?
4 ANTWORTEN 4
Nachricht 2 von 5
BIMAbhi
als Antwort auf: fpensa
Nachricht 3 von 5
fpensa
als Antwort auf: BIMAbhi
Thanks, already tried all of that...
Addins folder is empty.. fir whatever reason, it seems all my addins got deleted... however how is it that uninstall et reinstall Revit did not bring the standard addin back?
I was able to re-install the stand alone addins like NWC Exporter and eTransmit, but I don't know about all the others (Batc Print, model Review, ...)
Nachricht 4 von 5
BIMAbhi
You can get the add-ins from the previously shared link (in bottom portion)
Thanks & Regards
BIMAbhi
Nachricht 5 von 5
fpensa
Those I need are all supposed to be built in
Let's take Batch print for example. In the linked page it readdressed to the Autodesk App Store
But Batch Printing is not an app available in the App Store...
Same with the others...
