Adding watermark to Autodesk Viewer.
1 ANTWORT 1
Nachricht 1 von 2
Nishchay1
171 Aufrufe, 1 Antwort
Is there any way of adding watermarks into Autodesk viewer while uploading the BIM model?
Tags (2)
Beschriftungen (2)
1 ANTWORT 1
Nachricht 2 von 2
rxi.gg
als Antwort auf: Nishchay1
No you can't
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
