Adding vertical dimensions in 3d ismetric views
I see that adding dimensions to elements in 3d views works fine for plan type dimensions.  However it seems that adding vertical dimensions for elevation heights isn't working.  What do I need to be doing to dimension things vertically or on an angle or curves?  Is there a tutorial for that?
Thank You
Nardo
rosskirby
You need to set a work plane for the dimensions first.  In your 3D view, go to Architecture --> Set (on the Work Plane tab), and then select a face that is parallel to the dimensions you want to create.  You can set and re-set the work plane as many times as you want to get the dimensions you want.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
ChrisGamble
This behavior seems to no longer exist in Revit 2019.
cgambleTFFSQ
Never mind, the parallel/perpendicular plane setting threw me off, and  I was doing it wrong.
